Titewad powder used by anyone for 10mm or is it just too hot
Started by sstewart, March 19 2014 10:41:46 PM MDT
Taterhead
EDIT: I removed my original post after considering the fact that guys might take advice and load Titewad in a 10mm case. Just because I might be inclined to have a go under certain circumstances doesn't mean it is a practice that should be generally followed.
Pablo
Pretty sure I would never use Titewad with 10mm or 40SW. 45ACP?  Sure. No published loads for .25ACP OR .32ACP but that would be tempting. Only other loads I have seen published are 9mm.
Quote from: Pablo on May 03 2016 02:21:25 PM MDT
Those would be some tiny charges. You might have to count flecks (I don't think I can measure that small). 9mm light bullet loads are barely a little bit, as it is. Never tried it for .45ACP. I would never consider Titewad for high pressure cartridges, such as .40SW or 10mm.
sstewart
Titewad for 10mm is walking on a razor blade ...
Hodgdon shows the following for 45ACP using TiteWad  (These could be safe in the 10mm)
Hodgdon  Titewad  .451"  1.230" 155 GR. CAST LSWC  4.6 gr @ 1,015 fps  15,800 PSI   5.0 gr @  1,082 fps  18,800 PSI
Hodgdon  Titewad  .452"  1.140"  180 GR. LFP  3.7 gr @ 855 fps  14,800 PSI   4.3 gr @ 948 fps  19,200 PSI
Hodgdon  Titewad  .451"  1.155"  200 GR. SPR JHP  3.4 gr @ 680    fps 15,200 PSI   4.0 gr @ 834 fps 19,500 PSI
They show a few others but it does show just how little charges can generate some upper pressures in the 45ACP.
yeah... half a grain = a 4K psi jump.  That could get ugly fast.
