Armscor 180gr FMJ (copper plated)
Started by The_Shadow, December 19 2015 05:00:28 PM MST
Cartridge is from Ammo Manufacture: Armscor  180gr  FMJ (copper plated)(supplied by Intercooler 12-2015)
Muzzle Velocity: 1150 fps
Muzzle Energy: 529 ft. lbs
Brass Make/Headstamp: A USA - Brass
Bullet Make/Weight/Construction/Info; Length 0.5740"/Dia. 0.4000":  180gr. FMJ (plated)
Actual weigh 180.0 grains  Crimp Diameter 0.3990"
Meplat 0.2650" / Concaved Base
C.O.A.L.: 1.2470"
Primer: Nickel color
Case: Diameter 0.4200" Crimp Diameter 0.4220" Length 0.9860"
Powder Description/Positive ID/Type/Charge Weight: Tight Group  6.4 grains
RDub01
