Buffalo Bore 200gr FMJ-FN (Benchrest Mar 2016)
Started by The_Shadow, March 09 2016 05:43:09 PM MST
my_old_glock
#15
Quote from: The_Shadow on April 02 2016 06:42:23 PM MDT
Test Data added today...  4/2/2016  Star Line brass primer moderately flattened
Tested from the S&W 1006  1205 FPS  Case expansion 0.4275"  Factory 5.0" BBL
Tested from the Glock 20SF  1154 FPS Case expansion 0.4335"  Factory 4.6" BBL
Is this the Buffalo Bore, or the RCBS TCBB cast bullet and 8.4 grains of BE-86?
What weight spring do you have in the G20?
This is the Factory Buffalo Bore as listed and test from this Pull-down with the 9.0 grains of BE-86 from the S&W1006 and Glock 20SF.
I actually forgot to test the handloads yesterday as I started loosing the evening sun... :-[
Pctechdude
Quote from: The_Shadow on March 09 2016 06:00:24 PM MST
Consistency with measures of the BE-86 has been great in my loadings with it.  Now I need to up my own game with this powder, it is why I waited to find and bought the 8lb jug!   :o
Shadow, I was torn as I've been using a lot of Bullseye for 9mm 115gr fmj's. I was at the sportsman den and they had both Bullseye and BE-86. I checked with the lady at the counter and both were the same price, $124.99 for 8#. I said to hell with the bullseye and walked out with the BE-86! lol
Best part is, it's a large gun store, with a very small reloading section, so a lot of people don't go there for the powder and primers thankfully! The Hodgdon offerings they had HP-38/WIN231 Titegroup/CFE pistol, Autocomp was all around $145-$159. Then looking online, seemed pretty good deal for the BE-86
I liked the data for BE-86 from the get go, but the more I use it the more I like this powder even more.  I originally purchased it as a "what if SHTF", where it would bring a good balance of performance and little goes a long ways economics for my loading needs.  Be a flash suppressed powder also helps.
