10mm gel tests
Good test and worth sending those PPU's down. Now I can pester them! ;D
The 155 TAC-XP over 8.2 grains of IMR800X was right at the 1200 fps mark, that's what I was thinking that 8.4 would be there or slightly above.  Great job
the HST did better than I thought, and it really rocked that gel at that velocity. I think you found the sweet spot for them.
The PPU's expanded too. They might make a decent load after all when  driven properly.
Raggedyman
Are the PPUs available as a component?
No. But we can pester them to up their velocity!
Raggedyman
How responsive do you expect the Serbians to be?
   I e-mailed the U.S. group.
Let us know. I hope it works!
Raggedyman
Me too. I don't mean to be a wet blanket; I'd like some decent, cheap 10mm ammo, too. That PPU stuff was cheaper than most ball ammo and if they put some more powder in there, they'd be set. 880 fps is way too slow for even .40 S&W.
PBR is the hit if he ever has some to offer up.
Raggedyman
10mm CORBON 135 gr Pow'RBall
10mm CORBON 135 gr Pow'RBall fired from 4.5" bbl EAA Witness through four layers of denim into calibrated gelatin.
BB calibration: 600.8", 3.5"
Impact velocity: (Err), 1,425 fps
Penetration: 8.6", 8.6"
Retained weight: 129.3 gr, 122.9 gr
Max expansion: 0.848", 0.882"
Min expansion: 0.794", 0.702"
10mm Double Tap 200 gr Nosler
10mm Double Tap 200 gr Nosler fired from 4.5" bbl EAA Witness through four layers of denim into calibrated gelatin.
BB calibration: 582.9", 3.25"
Velocity: 1,076, (Err)
Penetration: 14.8", 15.5"
Retained weight: 193.8 gr, 192.7 gr
Max expansion: 0.704", 0.679"
Min expansion: 0.662", 0.572"
Well that is interesting...Thanks for the info!  8)
Raggedyman
My pleasure.
Forgot to embed:
RMM
Thanks for the tests!  The Nosler seemed to do ok.  I wouldn't want to carry that pow'rball, not even close to enough penetration.  The Nosler 135 seems like it would hold up a lot better at those speeds.
Richard - G20SF
