Trigger fixed
Started by Wyocaddis, February 08 2023 02:25:50 PM MST
Wyocaddis
Trigger fixed on RIA FS was over 6#. Fixed with a match sear spring now 2 3/4 to 3#. On my Lyman gauge. Now just oversized firing pin stop, and 22# recoil spring and should be set.
Rick B.
That?s a nice weight for range work or other, but for carry it would make me a little nervous
Wyocaddis
use a different pistol for carry.
Rick B.
38_Super
Quote from: Wyocaddis on February 08 2023 02:25:50 PM MST
After all the changes I made to my RIA to make it reliable the trigger pull is 6lbs.
You reduced the 6lb trigger pull to 3lbs just by changing the sear spring?
May I ask what sear spring you installed?
Wyocaddis
Rick B.
Wyocaddis
Rick B.
38_Super
Thanks for the tip.  Did you need to do any adjusting of the spring?
Wyocaddis
Rick B.
Wyocaddis
#8
everyday carry is a Sig P365XL with underwood 124gr. Speer gold dot.
Rick B.
