308 Winchester about to hit the press...
Started by The_Shadow, September 01 2025 01:31:50 PM MDT
Here are some of the components I obtained for this 308 Winchester project...
Will be loading them with Hodgdon 223CFE powder as I get the time to work on this project.
Over 260 Nickel 308 brass mostly Federal Cartridge.
250 of the 179gr Terminal Match Boat Tail HP from American Reloader
Also got these Starline 308 Win brass while browsing Sportsman's Wearhouse a while back...
crockett
I stock 2 categories of brass:
1.) Starline for all ladders, SD / HD, benchrest.
2.) Mil and range findings for average range days.
That being said, I avoid nickle like the plague. It's so damn stiff and brittle, and they don't last.
The nickel brass basically gifted to me from a good friend of mine for a handshake.  But being the man I am I slid $30 into his hand just because of the things he does at times.  Heck last time he gave me 500 230 grain 45 new Hornady bullets and 44 and 45 cast bullets he didn't need and a bunch of 7mm cartridges and 6.5 cartridges that all needed to be pulled to salvage bullets.
crockett
Quote from: The_Shadow on September 01 2025 04:01:56 PM MDTThe nickel brass basically gifted to me from a good friend of mine for a handshake.  But being the man I am I slid $30 into his hand just because of the things he does at times.  Heck last time he gave me 500 230 grain 45 new Hornady bullets and 44 and 45 cast bullets he didn't need and a bunch of 7mm cartridges and 6.5 cartridges that all needed to be pulled to salvage bullets.
Now that is a gift I would not turn away. It beats being on all fours at the range, like a bum.  ;D
On the other hand, I love finding rare caliber brass. I'm known to have bought firearms and dies jest because I found some odd casings. And I only buy the top of the line Redding dies too.......
10 Round
Been there done that I may not be a bum but the wife calls me an ass
crockett
This thread needs an update with photos, or it didn't happen!
#6
Well got all 263 of the 308 Win nickel brass full length resized and deprimed...None got stuck! ;D
Thanks Imperial Sizing Die Wax.  8)   240 Federal 1 Speer 18 Hornady 4 Winchester
#7
Well managed to get all the primer pockets cleaned and New CCI 200 primers are installed using the Ram Prime setup working on the top of the press adjusted for precise seating depth.  I leave the press handle in the down position to place the primer in the seating stem, raise the handle just enough which lowers the primer seater for the case to slide into the shellholder, then lower the handle to seat the primer.  The weight of the press handle is almost enough the seat them, just a light push down.
I have never used the Ram Prime, but have recommended it quite often as one of the cheapest priming options.  Good to hear you like it and that my recommendations are for something other than price.
When I just have a small group to prime I use my Lee Breechlock Challenger press with it's built in primer set up.  It primes on the up-stroke and doesn't offer the same seating depth control the Ram Prime does, but for just a few cases it is faster than setting up other options.  I used it yesterday as I had about a dozen cases to prime.
#9
Well had a little time and sat down and got all the 308Win loaded with the 179 grain Terminal Match bullets.
Here are the specs I went with:
308 Winchester
Terminal Match 179 gr BTHP
CFE223  45.2 grains
Large Rifle CCI 200 primer
COL 2.800"  Federal Nickel
Velocity: 2630 fps(estimated from 24" BBL data)
Energy:   2750 Ft Lbs
Total powder used 1.640114285714286 lbs
