Intercooler...About your Witness Match
Started by sqlbullet, June 14 2012 08:22:40 AM MDT
You had the crack in the frame right behind the mag release right?
I checked mine out the other day, and same exact thing.  Doesn't cause me any issues so I am leaving it alone.  Did EAA do anything for you?
   I contacted EAA and Henning for information. What the end result was is models like the Limited, Hunter, Gold Cup, etc.... got a factory relief cut at the Mag release. Supposedly the new Match pistols may or may not have it. That area is so thin it happens. No worries! EAA and Henning confirmed it won't hurt a thing. Just did what the factory should have done. My Hunter has a bigger relief cut from the factory.
pacapcop
Maybe i can assist here.My Match was manufactured in May 2012 and Imported out.When you say relief cut at the mag release,what am i looking for?
Thanks for the info.  that is what i expected.  i won't hurt it and it won't hurt me!
Where the Mag release button is (black button) it will split to the backside where the magwell is.
Try a picture.
Yep, that is exactly what mine looks like.
Nuke
Darn it! :(
I wanted a Hunter. Not now,,, grrrrr. If I wanted cracks in a 10mm I would by a Delta.  >:(
pacapcop
Ok went over my new Match.I took of plastic grips  to see where your issue was.Went onto other thread to see pics of your Match and Hunter.Just to clarify,when you said the relief cut was in(Inverted) is that the line that extends from bottom of mag well to top of frame just above the rail?If so,nothing showing inward on my Match.Bear with me,some pics are indeed showing inward line cuts from what you posted.
alwaysshootin
Quote from: Nuke on June 17 2012 02:09:33 PM MDT
Darn it! :(
Sorry, but that is not, a confidence builder!
having a match with the crack i would say it is far less of an issue than the plastic sights on my glock 22 were.
The Hunter has a factory cut relief cut in. I posted pictures of it and a Limited. The line is just cleaner.
pacapcop
#13
Went over my Match.It appears there is no sign of a relief cut in.However i will check over course of time as i do with all guns.
Post some pictures of it. Did you shoot it yet?
