Freedom Munitions Ammo 180gr Hornady XTP (supplied by Blades 5/2016)
Started by The_Shadow, May 09 2016 08:25:35 PM MDT
Cartridge is from Ammo Manufacture: Freedom Munitions  Ammo 180gr Hornady XTP (supplied by Blades 5/2016)
Muzzle Velocity: 1120 fps
Muzzle Energy: 501 ft. lbs
Brass Make/Headstamp: FREEDOM - Brass
Bullet Make/Weight/Construction/Info; Length 0.6235"/Dia. 0.4000": 180gr Hornady XTP
Actual weigh 180.2 grains / Flat base / Crimp Diameter 0.3990"
HP Dia 0.1325"  HP Depth 0.1800" Mouth 0.2180"
C.O.A.L.: 1.2545" / 1.2545" / 1.2555"
Case: Diameter 0.4215" Crimp Diameter 0.4205" (medium crimp)Length 0.9880"
Powder Description/Positive ID/Type/Charge Weight: ? WSF 6.6 grains  *
