Herter's Select Grade 180gr FMJ and JHP
Started by Intercooler, September 15 2018 05:37:29 PM MDT
Found at Cabela's today! Good Ole S&B makes it for them. I didn't get the JHP version and suspect these FMJ's to equal the S&B version.
I am sure there will be a range report forthcoming.
Glad to see more manufacturers coming out with 10mm ammo, even if it is weak sauce.
Thanks guys, if the price is right & it performs well, then hey 😊
10mm Auto  180 Grain  FMJ   1,164 fps   543 ft. lbs.  Good practice ammo.
No mention of JHP ammo by Herter's... ???
At $18.00 for 50 rd's, absolutely worth looking into, Thanks man!
#7
I wonder if their website is behind what's on the shelf? If I recall correctly they had Herter's Self Defense in other calibers like 9mm as well. It's a red box... I picked it up, opened the flap and slid one of the 25 packs out to look at the hollow point. It was the same design as the S&B which prompted me to just put it back.
I went up that way to do a return today and stopped in Cabela's again. They for sure don't have the website updated to the stores! Here is the 10mm JHP's
They had Herter's brand JHP in all the popular calibers as well.
How would this compare with UW's range supply?, it's only two dollars less
It will have less velocity and you can shoot it all day. I use something like this a little scaled back when I'm checking my sight adjustments out. It's good bang for the buck!
mr.revolverguy
I can confirm Herters is S&B but the JHP is a bit hotter I will be publishing a video soon. The powder used across both is LOVEX D036.07 all to be published soon but Intercooler beat me to it :)
