CCI Blazer 200 gr. TMJ #3597 (Redline 8/19)
Started by The_Shadow, August 15 2019 11:22:53 AM MDT
Cartridge is from Ammo Manufacture: CCI Blazer 200 gr. TMJ #3597 (Redline 8/19)
Muzzle Velocity: 1050 fps
Muzzle Energy:    490 ft. lbs
Brass Make/Headstamp: CCI – Aluminum NR (non reloadable)
Bullet Make/Weight/Construction/Info; Length 0.6615"/Dia. 0.4000": CCI 200 gr. TMJ
MEPLAT 0.2480" (concave base)
Actual weight 199.6 / 200.0 / 199.8 grains   Crimp squeezed bullet to 0.3970"
C.O.A.L.: 1.250" / 1.2490" / 1.2500"
Primer: Small Pistol Primer Brass color (this is different boxer primer)
Case: Diameter 0.4220" Crimp Diameter 0.4205" (light) Length 0.9890"
Powder Description/Positive ID/Type/Charge Power Pistol Weight: 7.0 / 7.0 / 7.0 grains
(has soft translucent grey color off white flakes)
Cartridge weight: 235.0 / 234.6 / 234.8
Notes: GREAT ECONOMY THROUGH GREAT TECHNOLOGY. If casual practice is getting expensive, look to Blazer®. Blazer uses aircraft-grade aluminum that's heat-treated to make an economical cartridge case. As the case is the most expensive component of any cartridge, our aluminum case lets us give you a cartridge that has all the performance of brass-case ammo at a more attractive price. We load Speer bullets and CCI primers, both with a long record of happy users.
